Aller au contenu principal
Dell Inspiron 11 3169 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 11 3169 Display Assembly Replacement, Remove the Screw: étape 1, image 1 de 1
  2. Dell Inspiron 11 3169 Display Assembly Replacement, Lifting the Display-Cable: étape 2, image 1 de 1
    • Lift the display-cable bracket off the system board.
  3. Dell Inspiron 11 3169 Display Assembly Replacement, Peeling off the Tape: étape 3, image 1 de 2 Dell Inspiron 11 3169 Display Assembly Replacement, Peeling off the Tape: étape 3, image 2 de 2
    • Peel off the tape to access the display cable.
  4. Dell Inspiron 11 3169 Display Assembly Replacement, Open the Latch: étape 4, image 1 de 1
    • Open the latch and disconnect the display cable.
  5. Dell Inspiron 11 3169 Display Assembly Replacement, Open the Latch: étape 5, image 1 de 3 Dell Inspiron 11 3169 Display Assembly Replacement, Open the Latch: étape 5, image 2 de 3 Dell Inspiron 11 3169 Display Assembly Replacement, Open the Latch: étape 5, image 3 de 3
    • Open the latch and disconnect the sensor-board cable from the I/O board.
  6. Dell Inspiron 11 3169 Display Assembly Replacement, Peeling the Tapes: étape 6, image 1 de 1
    • Peel the tapes off the display hinges.
  7. Dell Inspiron 11 3169 Display Assembly Replacement, Opening the Display: étape 7, image 1 de 1
    • Turn the computer over and open the display as far as possible.
    • CAUTION: Place the computer on a soft and clean surface to avoid scratching the display.
  8. Dell Inspiron 11 3169 Display Assembly Replacement, Remove the Screws: étape 8, image 1 de 1
    • Place the computer face down on a flat surface.
    • Remove the screws that secure the display assembly to the palm-rest and keyboard assembly.
  9. Dell Inspiron 11 3169 Display Assembly Replacement, Lifting the Display Assembly: étape 9, image 1 de 1
    • Lift the display assembly off the palm-rest and keyboard assembly.
  10. Dell Inspiron 11 3169 Display Assembly Replacement, Placing the Display Assembly: étape 10, image 1 de 1
    • Place the display assembly on the palm-rest and keyboard assembly.
  11. Dell Inspiron 11 3169 Display Assembly Replacement, Align the Screw Holes: étape 11, image 1 de 1
    • Align the screw holes on the display hinges with the screw holes on the palm-rest and keyboard assembly.
  12. Dell Inspiron 11 3169 Display Assembly Replacement, Replace the Screws: étape 12, image 1 de 1
    • Replace the screws that secure the display assembly to the palm-rest and keyboard assembly.
  13. Dell Inspiron 11 3169 Display Assembly Replacement, Sliding the I/O Board Cable: étape 13, image 1 de 2 Dell Inspiron 11 3169 Display Assembly Replacement, Sliding the I/O Board Cable: étape 13, image 2 de 2
    • Turn the computer over and close the display.
    • Slide the I/O-board cable into its slot on the system board and press down the latch to secure the cable.
  14. Dell Inspiron 11 3169 Display Assembly Replacement, Routing the Antenna Cable: étape 14, image 1 de 1
    • Route the antenna cable through its routing on the right speaker.
  15. Dell Inspiron 11 3169 Display Assembly Replacement, Sliding the Sensor-Board Cable: étape 15, image 1 de 2 Dell Inspiron 11 3169 Display Assembly Replacement, Sliding the Sensor-Board Cable: étape 15, image 2 de 2
    • Slide the sensor-board cable into its slot on the I/O board and press down the latch to secure the cable.
  16. Dell Inspiron 11 3169 Display Assembly Replacement, Sliding the Display Cable: étape 16, image 1 de 1
    • Slide the display cable into its slot on the system board and press down the latch to secure the cable.
  17. Dell Inspiron 11 3169 Display Assembly Replacement, Adhering the Tape: étape 17, image 1 de 1
    • Adhere the tape on the display cable.
Terrence15
Membre depuis le 12/18/17
79 522 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 6
Total : 334
