Aller au contenu principal
Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement, Processor Fan and Heat Sink: étape 1, image 1 de 1
    • Close the computer and turn it over, with the bottom of the computer facing up.
  2. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: étape 2, image 1 de 1
    • Remove the nine 7.6mm PH0 screws on the cover.
  3. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: étape 3, image 1 de 1
    • Use a plastic opening tool to remove the cover from the computer.
  4. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: étape 4, image 1 de 1
    • Remove the three 4.7mm PH0 screws that secure the battery to the computer.
  5. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: étape 5, image 1 de 1
    • Remove the hard drive cable from the battery.
  6. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: étape 6, image 1 de 1
    • Lift the battery from the keyboard.
  7. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: étape 7, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
  8. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: étape 8, image 1 de 1
    • Use a screwdriver to remove the two 2.3mm PH00 screws on the processor fan.
  9. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: étape 9, image 1 de 1
    • Use a PH0 screwdriver to loosen the 4 captured screws on the heat sink assembly.
  10. Dell Inspiron 11 i3147 Processor Fan and Heat Sink Replacement: étape 10, image 1 de 1
    • Remove the processor fan and heat sink assembly.
Muhammad Erchid
Membre depuis le 10/09/18
1 069 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G6, Leahy Fall 2018 Membre de l'équipe USF Tampa, Team S1-G6, Leahy Fall 2018
USFT-LEAHY-F18S1G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 279
