Aller au contenu principal
Dell Inspiron 11-3147 CMOS Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 11-3147 CMOS Battery Replacement, CMOS Battery: étape 1, image 1 de 2 Dell Inspiron 11-3147 CMOS Battery Replacement, CMOS Battery: étape 1, image 2 de 2
    • Using a plastic Philips Head #1 Screw Driver, remove the nine 7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic spudger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 CMOS Battery Replacement: étape 2, image 1 de 1
    • Using a plastic spudger, gently press under the battery to lift it up and out.
  3. Dell Inspiron 11-3147 CMOS Battery Replacement: étape 3, image 1 de 1
    • Remove the CMOS Battery
William Brum
Membre depuis le 03/04/16
755 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-1, Bhusal Spring 2016 Membre de l'équipe UMass Dartmouth, Team 3-1, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G1
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 24
30 derniers jours : 51
Total : 3,286
