Aller au contenu principal
Dell Inspiron 11-3147 RAM Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 11-3147 RAM Replacement, RAM: étape 1, image 1 de 2 Dell Inspiron 11-3147 RAM Replacement, RAM: étape 1, image 2 de 2
    • Using a Philips Head #1 Screw Driver remove the nine .7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic plunger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 RAM Replacement: étape 2, image 1 de 2 Dell Inspiron 11-3147 RAM Replacement: étape 2, image 2 de 2
    • Place finger nails on both of the little metal tabs that are located on shorter sides of the Ram board.
    • Pull tabs outward and away from the Ram card. This will detach the card from the computer and allow removal.
  3. Dell Inspiron 11-3147 RAM Replacement: étape 3, image 1 de 1
    • Carefully remove the RAM to ensure no other components get damaged.
    • Replace with a new RAM card the exact way it came out, with the the shiny metallic part of the card placed inside black insert as shown in the picture.
4 autres ont terminé cette réparation.
William Brum
Membre depuis le 03/04/16
755 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-1, Bhusal Spring 2016 Membre de l'équipe UMass Dartmouth, Team 3-1, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G1
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 20
Total : 1,342
