Aller au contenu principal
Dell Inspiron 11-3147 Replace the Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 11-3147 Replace the Battery Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 11-3147 Replace the Battery Replacement, Battery: étape 1, image 2 de 2
    • Using a Philips Head #1 Screw Driver remove the nine .7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic plunger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 Replace the Battery Replacement: étape 2, image 1 de 1
    • The 4mm battery screws can be removed with a philips head #0 screw driver. All the screws that must be removed are shown in the attached pictures.
    • Place screws close by in a safe place such as a magnetic board or cup so they are ready and accounted for when you begin reassembly.
  3. Dell Inspiron 11-3147 Replace the Battery Replacement: étape 3, image 1 de 1
    • Once the screws have been removed the battery may then be simply removed by hand and replaced.
3 autres ont terminé cette réparation.
William Brum
Membre depuis le 03/04/16
737 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-1, Bhusal Spring 2016 Membre de l'équipe UMass Dartmouth, Team 3-1, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G1
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 17
Total : 2,489
