Aller au contenu principal
Dell Inspiron 11-3152 Screen Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 11-3152 Screen Replacement, Back Panel: étape 1, image 1 de 2 Dell Inspiron 11-3152 Screen Replacement, Back Panel: étape 1, image 2 de 2
    • Flip the computer over.
  2. Dell Inspiron 11-3152 Screen Replacement: étape 2, image 1 de 2 Dell Inspiron 11-3152 Screen Replacement: étape 2, image 2 de 2
    • Remove all nine 5mm Phillips head screws from the back cover using #0 Phillips head.
  3. Dell Inspiron 11-3152 Screen Replacement: étape 3, image 1 de 1
    • Gently use a spudger to pull the cover away from the rest of the laptop. The cover will come off after you use the tool on two or three sides.
  4. Dell Inspiron 11-3152 Screen Replacement, Battery: étape 4, image 1 de 1
    • Make sure that the power is off.
    • After taking off the back panel, you will see the battery located at the bottom of the computer system. It's black and is clearly labeled "dell battery".
  5. Dell Inspiron 11-3152 Screen Replacement: étape 5, image 1 de 2 Dell Inspiron 11-3152 Screen Replacement: étape 5, image 2 de 2
    • Locate the battery at the bottom of the computer and remove the four 3mm screws with a Phillips #0 head that hold the battery down.
  6. Dell Inspiron 11-3152 Screen Replacement: étape 6, image 1 de 1
    • Remove the Solid State Drive wire from the battery clip by detaching the wire.
    • This can be done by gently pulling the connector away from the battery clip.
  7. Dell Inspiron 11-3152 Screen Replacement: étape 7, image 1 de 1
    • Remove the battery from the computer system by gently lifting it from the side.
  8. Dell Inspiron 11-3152 Screen Replacement, Screen: étape 8, image 1 de 1
    • Unscrew the brackets in the top right and top left of the laptop. Unscrew the two 1mm screw from both of the brackets on both sides with #0 phillips head.
  9. Dell Inspiron 11-3152 Screen Replacement: étape 9, image 1 de 1
    • Disconnect the aerial cables from the wireless controller by pulling them away from the laptop.
  10. Dell Inspiron 11-3152 Screen Replacement: étape 10, image 1 de 1
    • Push the brackets up on both sides with your hands or spudger.
  11. Dell Inspiron 11-3152 Screen Replacement: étape 11, image 1 de 2 Dell Inspiron 11-3152 Screen Replacement: étape 11, image 2 de 2
    • At this point you can pull the bottom half of the computer away from the screen.
    • The screen is now fully detached and ready to be replaced!
Matthew Duncan
Membre depuis le 03/10/16
481 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-6, Catania Spring 2016 Membre de l'équipe UMass Dartmouth, Team 4-6, Catania Spring 2016
UMASSD-CATANIA-S16S4G6
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 12
30 derniers jours : 13
Total : 554
