Aller au contenu principal
Dell Inspiron 11-3162 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 11-3162 Display Assembly Replacement, Remove the Screw: étape 1, image 1 de 1
  2. Dell Inspiron 11-3162 Display Assembly Replacement, Lifting the Display Cable: étape 2, image 1 de 1
    • Slide and lift the display-cable bracket off the system board.
  3. Dell Inspiron 11-3162 Display Assembly Replacement, Open the Latch: étape 3, image 1 de 2 Dell Inspiron 11-3162 Display Assembly Replacement, Open the Latch: étape 3, image 2 de 2
    • Open the latch and disconnect the display cable from the system board.
  4. Dell Inspiron 11-3162 Display Assembly Replacement, Open the Palm Rest: étape 4, image 1 de 1
    • Open the palm rest and keyboard assembly at an angle.
  5. Dell Inspiron 11-3162 Display Assembly Replacement, Remove the Screws: étape 5, image 1 de 1
    • Remove the screws that secure the display assembly to the palm rest and keyboard assembly.
  6. Dell Inspiron 11-3162 Display Assembly Replacement, Lifting the Assemblies: étape 6, image 1 de 1
    • Slide and lift the palm rest and keyboard assembly off the display assembly.
  7. Dell Inspiron 11-3162 Display Assembly Replacement, Placing the Display Assembly: étape 7, image 1 de 1
    • Place the NEW display assembly on a flat and clean surface.
  8. Dell Inspiron 11-3162 Display Assembly Replacement, Align the Screw Holes: étape 8, image 1 de 1
    • Align the screw holes on the display hinges with the screw holes on the palm rest and keyboard assembly.
  9. Dell Inspiron 11-3162 Display Assembly Replacement, Replace the Screws: étape 9, image 1 de 1
    • Replace the screws that secure the display assembly to the palm rest and keyboard assembly.
  10. Dell Inspiron 11-3162 Display Assembly Replacement, Securing the Cable: étape 10, image 1 de 1
    • Slide the display cable into the connector on the system board and close the latch to secure the cable.
  11. Dell Inspiron 11-3162 Display Assembly Replacement, Sliding the Display Cable: étape 11, image 1 de 1
    • Slide the display-cable bracket into the slot on the palm rest and keyboard assembly.
  12. Dell Inspiron 11-3162 Display Assembly Replacement, Align the Screw Hole: étape 12, image 1 de 1
    • Align the screw hole on the display-cable bracket with the screw hole on the system board.
  13. Dell Inspiron 11-3162 Display Assembly Replacement, Replace the Screw: étape 13, image 1 de 1
    • Replace the screw that secures the display-cable bracket to the system board.
Terrence15
Membre depuis le 12/18/17
79 161 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 986 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 8
Total : 504
