Aller au contenu principal
Dell Inspiron 11-3164 Mousepad Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 11-3164 Mousepad Replacement, Mousepad: étape 1, image 1 de 2 Dell Inspiron 11-3164 Mousepad Replacement, Mousepad: étape 1, image 2 de 2
    • Place laptop upside down to observe the first set of screws on the bottom cover. With the J1 Phillips head screwdriver bit, unscrew eight (8) size 60 mm screws.
    • With a metal spudger, remove the plastic cover to unveil the final screw.
    • With the J1 Phillips head bit, remove remaining 60 mm screw.
  2. Dell Inspiron 11-3164 Mousepad Replacement: étape 2, image 1 de 2 Dell Inspiron 11-3164 Mousepad Replacement: étape 2, image 2 de 2
    Outil utilisé dans cette étape :
    • With a metal spudger, pry apart the bottom cover working around the edges.
    • While separating the halves of the bottom cover, carefully move the spudger up and down to avoid damaging the USB/Audio circuit board cable inside.
    • With tweezers, disconnect the USB/Audio circuit board cable.
    • Place the bottom cover off to the side.
  3. Dell Inspiron 11-3164 Mousepad Replacement: étape 3, image 1 de 1
    • With the J1 screwdriver bit, unscrew three (3) size 40 mm battery screws.
  4. Dell Inspiron 11-3164 Mousepad Replacement: étape 4, image 1 de 1
    • With tweezers, disconnect the battery cable.
    • Remove the battery pack.
  5. Dell Inspiron 11-3164 Mousepad Replacement: étape 5, image 1 de 3 Dell Inspiron 11-3164 Mousepad Replacement: étape 5, image 2 de 3 Dell Inspiron 11-3164 Mousepad Replacement: étape 5, image 3 de 3
    • With tweezers, disconnect the keyboard cable
    • With tweezers, disconnect the touchpad cable.
    • With the Philips #00 Screwdriver, loosen the 4 - M2 x 2mm screws
    • Gently remove the mouse touchpad.
Michael Kendziora
Membre depuis le 02/14/18
781 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S6-G4, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S6-G4, Eyestone Spring 2018
USFT-EYESTONE-S18S6G4
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 3
Total : 214
