Aller au contenu principal
Dell Inspiron 11-3168 Memory modules Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 11-3168 Memory modules Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 11-3168 Memory modules Replacement, Battery: étape 1, image 2 de 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Memory modules Replacement: étape 2, image 1 de 3 Dell Inspiron 11-3168 Memory modules Replacement: étape 2, image 2 de 3 Dell Inspiron 11-3168 Memory modules Replacement: étape 2, image 3 de 3
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Memory modules Replacement: étape 3, image 1 de 2 Dell Inspiron 11-3168 Memory modules Replacement: étape 3, image 2 de 2
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Memory modules Replacement: étape 4, image 1 de 2 Dell Inspiron 11-3168 Memory modules Replacement: étape 4, image 2 de 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Memory modules Replacement: étape 5, image 1 de 3 Dell Inspiron 11-3168 Memory modules Replacement: étape 5, image 2 de 3 Dell Inspiron 11-3168 Memory modules Replacement: étape 5, image 3 de 3
    • Remove the battery.
  6. Dell Inspiron 11-3168 Memory modules Replacement, Memory modules: étape 6, image 1 de 3 Dell Inspiron 11-3168 Memory modules Replacement, Memory modules: étape 6, image 2 de 3 Dell Inspiron 11-3168 Memory modules Replacement, Memory modules: étape 6, image 3 de 3
    • Press down on the two latches on either side of the memory module.
    • Lift and remove the memory module.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 15
Total : 822
