Aller au contenu principal
Dell Inspiron 11-3168 Screen Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 11-3168 Screen Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 11-3168 Screen Replacement, Battery: étape 1, image 2 de 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Screen Replacement: étape 2, image 1 de 3 Dell Inspiron 11-3168 Screen Replacement: étape 2, image 2 de 3 Dell Inspiron 11-3168 Screen Replacement: étape 2, image 3 de 3
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Screen Replacement: étape 3, image 1 de 2 Dell Inspiron 11-3168 Screen Replacement: étape 3, image 2 de 2
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Screen Replacement: étape 4, image 1 de 2 Dell Inspiron 11-3168 Screen Replacement: étape 4, image 2 de 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Screen Replacement: étape 5, image 1 de 3 Dell Inspiron 11-3168 Screen Replacement: étape 5, image 2 de 3 Dell Inspiron 11-3168 Screen Replacement: étape 5, image 3 de 3
    • Remove the battery.
  6. Dell Inspiron 11-3168 Screen Replacement, Screen: étape 6, image 1 de 3 Dell Inspiron 11-3168 Screen Replacement, Screen: étape 6, image 2 de 3 Dell Inspiron 11-3168 Screen Replacement, Screen: étape 6, image 3 de 3
    • Carefully flip the laptop over so that the top case is facing up.
    • Remove the top case of the laptop by gently prying along the seam with a plastic opening tool.
  7. Dell Inspiron 11-3168 Screen Replacement: étape 7, image 1 de 3 Dell Inspiron 11-3168 Screen Replacement: étape 7, image 2 de 3 Dell Inspiron 11-3168 Screen Replacement: étape 7, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Use a pair of tweezers to grip the tape that is holding down the display cable clip.
    • Gently unpeel the tape. This will release the clip that locks over the display connector socket.
    • Once unclipped, remove the display cable from the socket.
  8. Dell Inspiron 11-3168 Screen Replacement: étape 8, image 1 de 3 Dell Inspiron 11-3168 Screen Replacement: étape 8, image 2 de 3 Dell Inspiron 11-3168 Screen Replacement: étape 8, image 3 de 3
    • Find the smaller ZIF connector. Using tweezers, carefully lift the black flap on the connector to release the ribbon cable.
  9. Dell Inspiron 11-3168 Screen Replacement: étape 9, image 1 de 2 Dell Inspiron 11-3168 Screen Replacement: étape 9, image 2 de 2
    • Disconnect the webcam module located at the top of the monitor.
  10. Dell Inspiron 11-3168 Screen Replacement: étape 10, image 1 de 2 Dell Inspiron 11-3168 Screen Replacement: étape 10, image 2 de 2
    • Lift and remove the display screen from the top case.
Tyson Pace
Membre depuis le 01/17/19
464 Réputation
3 tutoriels rédigés
Un commentaire
how much did this display cost?
Ibrahim Ahmed Mohamed - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 741
