Aller au contenu principal
Dell Inspiron 11-3168 Wifi module Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 11-3168 Wifi module Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 11-3168 Wifi module Replacement, Battery: étape 1, image 2 de 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
  2. Dell Inspiron 11-3168 Wifi module Replacement: étape 2, image 1 de 3 Dell Inspiron 11-3168 Wifi module Replacement: étape 2, image 2 de 3 Dell Inspiron 11-3168 Wifi module Replacement: étape 2, image 3 de 3
    • Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
  3. Dell Inspiron 11-3168 Wifi module Replacement: étape 3, image 1 de 2 Dell Inspiron 11-3168 Wifi module Replacement: étape 3, image 2 de 2
    • Remove the one 7.5mm screw that is holding the battery in place.
  4. Dell Inspiron 11-3168 Wifi module Replacement: étape 4, image 1 de 2 Dell Inspiron 11-3168 Wifi module Replacement: étape 4, image 2 de 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  5. Dell Inspiron 11-3168 Wifi module Replacement: étape 5, image 1 de 3 Dell Inspiron 11-3168 Wifi module Replacement: étape 5, image 2 de 3 Dell Inspiron 11-3168 Wifi module Replacement: étape 5, image 3 de 3
    • Remove the battery.
  6. Dell Inspiron 11-3168 Wifi module Replacement, Wifi module: étape 6, image 1 de 3 Dell Inspiron 11-3168 Wifi module Replacement, Wifi module: étape 6, image 2 de 3 Dell Inspiron 11-3168 Wifi module Replacement, Wifi module: étape 6, image 3 de 3
    • Use an opening tool or your fingers to release the clamps on both ends of the ribbon cable and lift away.
  7. Dell Inspiron 11-3168 Wifi module Replacement: étape 7, image 1 de 3 Dell Inspiron 11-3168 Wifi module Replacement: étape 7, image 2 de 3 Dell Inspiron 11-3168 Wifi module Replacement: étape 7, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the screw that is holding the WiFi module in place.
    • Remove the metal piece that covers the antenna cable connectors.
  8. Dell Inspiron 11-3168 Wifi module Replacement: étape 8, image 1 de 3 Dell Inspiron 11-3168 Wifi module Replacement: étape 8, image 2 de 3 Dell Inspiron 11-3168 Wifi module Replacement: étape 8, image 3 de 3
    • To remove the WiFi module from the motherboard, slide it free of the socket connector.
  9. Dell Inspiron 11-3168 Wifi module Replacement: étape 9, image 1 de 3 Dell Inspiron 11-3168 Wifi module Replacement: étape 9, image 2 de 3 Dell Inspiron 11-3168 Wifi module Replacement: étape 9, image 3 de 3
    • Disconnect both the black and the white wires from the WiFi module.
To install the replacement module, start at step 4 and work your way backwards to step 1.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 20
Total : 568
