Introduction
In this guide, we will show you how to remove the Display Assembly.
Pièces
Aucune pièce nécessaire.
Follow the instructions in "Preparing to Work Inside the Computer."
  • Follow the instructions in "Preparing to Work Inside the Computer."
  • CAUTION: To prevent static damage to components inside your computer, discharge static electricity from your body before you touch any of your computer's electronic components. You can do so by touching an unpainted metal surface.
  • Close the display.
  • From the back of the computer, remove the two M2.5 x 5-mm screws labeled "circle D."
Ajouter un commentaire
Open the display assembly approximately 180 degrees, and support the display assembly so that it does not open past this position.
  • Open the display assembly approximately 180 degrees, and support the display assembly so that it does not open past this position.
  • Remove the two M2.5 x 5-mm screws from each hinge bracket.
  • Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
  • Lift the display assembly up and out of the computer base.
Terrence15
Membre depuis le 18/12/2017
69 301 Réputation
444 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
917 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 18
