Aller au contenu principal
Dell Inspiron 1100 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1100 Keyboard Replacement, Keyboard: étape 1, image 1 de 3 Dell Inspiron 1100 Keyboard Replacement, Keyboard: étape 1, image 2 de 3 Dell Inspiron 1100 Keyboard Replacement, Keyboard: étape 1, image 3 de 3
    • Remove the plastic face plate from the laptop using the iFixit Plastic Opening Tool.
    • Start by inserting the iFixit Plastic Opening Tool into the groove on the right side of the face plate.
    • This step does require some force. Be careful to not bend or break the plastic face plate.
  2. Dell Inspiron 1100 Keyboard Replacement: étape 2, image 1 de 2 Dell Inspiron 1100 Keyboard Replacement: étape 2, image 2 de 2
    • Remove the four 3mm Phillips #0 screws securing the keyboard.
  3. Dell Inspiron 1100 Keyboard Replacement: étape 3, image 1 de 1
    • Lift up the keyboard to expose the ribbon header on the motherboard.
    • Be careful as the keyboard can only move a little ways from the surface of the laptop and is easily damaged.
  4. Dell Inspiron 1100 Keyboard Replacement: étape 4, image 1 de 2 Dell Inspiron 1100 Keyboard Replacement: étape 4, image 2 de 2
    • Grip the ribbon on its hard plastic connector, and pull the ribbon and its connector out of the motherboard header.
    • Do not pull on the ribbon itself, as this may cause internal damage to the connector.
2 autres ont terminé cette réparation.
Alexander Pacheco
Membre depuis le 10/19/16
610 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-3, Isaacson Fall 2016 Membre de l'équipe UMass Dartmouth, Team 3-3, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G3
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 12
Total : 468
