Introduction
In this guide, we will show you how to remove and replace the Display Assembly.
Pièces
Aucune pièce nécessaire.
Follow the instructions in Before You Begin.
  • Follow the instructions in Before You Begin.
  • Disconnect the Mini-Card antenna cables from the Mini-Card(s).
Ajouter un commentaire
Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
  • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
  • Disconnect the display cable from the system board connector.
  • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  • Lift and remove the display assembly off the computer base.
  • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  • Connect the display cable to the system board connector.
  • Route the Mini-Card antenna cables through the routing guides on the computer base.
  • Connect the Mini-Card antenna cables to the Mini-Card(s).
Terrence15
Membre depuis le 18/12/2017
69 271 Réputation
444 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
917 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 13
