Aller au contenu principal
Dell Inspiron 11z-1121 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 11z-1121 Display Assembly Replacement, Disconnecting the Mini-Card Cables: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • Disconnect the Mini-Card antenna cables from the Mini-Card(s).
  2. Dell Inspiron 11z-1121 Display Assembly Replacement, Dislodge the Cables: étape 2, image 1 de 1
    • Make note of the cable routing and carefully dislodge the Mini-Card antenna cables from the routing guides.
  3. Dell Inspiron 11z-1121 Display Assembly Replacement, Disconnecting the Display Cable: étape 3, image 1 de 1
    • Disconnect the display cable from the system board connector.
  4. Dell Inspiron 11z-1121 Display Assembly Replacement, Remove the Screws: étape 4, image 1 de 1
    • Remove the two screws (one on each side) that secure the display assembly to the computer base.
  5. Dell Inspiron 11z-1121 Display Assembly Replacement, Lifting and Removing the Display Assembly: étape 5, image 1 de 1
    • Lift and remove the display assembly off the computer base.
  6. Dell Inspiron 11z-1121 Display Assembly Replacement, Replace the Screws: étape 6, image 1 de 1
    • Place the NEW display assembly in position and replace the two screws (one on each side) that secure the display assembly to the computer base.
  7. Dell Inspiron 11z-1121 Display Assembly Replacement, Connecting the Display Cable: étape 7, image 1 de 1
    • Connect the display cable to the system board connector.
  8. Dell Inspiron 11z-1121 Display Assembly Replacement, Routing the Cables: étape 8, image 1 de 1
    • Route the Mini-Card antenna cables through the routing guides on the computer base.
  9. Dell Inspiron 11z-1121 Display Assembly Replacement, Connecting the Cables: étape 9, image 1 de 1
    • Connect the Mini-Card antenna cables to the Mini-Card(s).
Terrence15
Membre depuis le 12/18/17
79 555 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 7
Total : 293
