Introduction
In this guide, we will show you how to remove and replace the Memory Modules.
Pièces
Aucune pièce nécessaire.
WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
  • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
  • Loosen the captive screw that secures the memory-module cover to the computer base.
Ajouter un commentaire
Lift the memory-module cover off the computer base.
  • Lift the memory-module cover off the computer base.
  • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
  • Use your fingertips to carefully spread apart the securing clips on each end of the memory module connector until the memory module pops up.
  • Remove the memory module from the memory-module connector.
  • Align the notch in the NEW memory module with the tab in the memory-module connector.
  • Slide the memory module firmly into the memory-module connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
  • NOTE: If the memory module is not installed properly, the computer may not boot.
  • Slide the tabs on the memory-module cover into the slots on the computer base and gently press the memory-module cover into place.
  • Tighten the screw that secures the memory-module cover to the computer base.
Terrence15
Membre depuis le 18/12/2017
69 271 Réputation
444 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
917 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 9
