Aller au contenu principal
Dell Inspiron 11z-1121 RAM Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 11z-1121 RAM Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 11z-1121 RAM Replacement, Battery: étape 1, image 2 de 2
    • Slide the latches outward to release the battery.
    • Pull the battery outward to remove.
    • The latches should lock in place, allowing for easy removal.
    • The battery must be removed for safety reasons when replacing other components of the laptop.
  2. Dell Inspiron 11z-1121 RAM Replacement, RAM: étape 2, image 1 de 2 Dell Inspiron 11z-1121 RAM Replacement, RAM: étape 2, image 2 de 2
    • With a Phillips #1, loosen the 1 mm screw attaching the access door to the laptop body
    • Using your fingers, remove the access door to expose the memory card
  3. Dell Inspiron 11z-1121 RAM Replacement: étape 3, image 1 de 2 Dell Inspiron 11z-1121 RAM Replacement: étape 3, image 2 de 2
    • To access the memory card, push out the lashes on the left and the right of the memory card.
    • To remove the memory card, use your fingers to pull it out with the lashes still stretched out.
Équipe
USF Tampa, Team 1-5, Nance Fall 2016 Membre de l'équipe USF Tampa, Team 1-5, Nance Fall 2016
USFT-NANCE-F16S1G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 20
Total : 475
