Introduction
In this guide, we will show you how to remove and replace the Battery.
Ce dont vous avez besoin
Disconnect the battery cable from the system board.
Remove the screws that secure the battery to the palm-rest assembly.
Press and hold the power button for five seconds to ground the system board.
Align the screw holes on the NEW battery with the screw holes on the palm-rest assembly.
Replace the screws that secure the battery to the palm-rest assembly.
Connect the battery cable to the system board.
2 autres ont terminé cette réparation.
Well, nice description, but you need to remove the bottom cover by first removing all the screws, then using a pry device, sliding it around the edge until you can pop off the bottom cover. THEN you can access the four screws on the battery.
Gregg Stanley - Réponse
