Aller au contenu principal
Dell Inspiron 13 7378 RAM Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 13 7378 RAM Replacement, Back Cover: étape 1, image 1 de 1
    • Set the laptop with its underside facing up for improved accessibility.
  2. Dell Inspiron 13 7378 RAM Replacement: étape 2, image 1 de 2 Dell Inspiron 13 7378 RAM Replacement: étape 2, image 2 de 2
    • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
  3. Dell Inspiron 13 7378 RAM Replacement: étape 3, image 1 de 3 Dell Inspiron 13 7378 RAM Replacement: étape 3, image 2 de 3 Dell Inspiron 13 7378 RAM Replacement: étape 3, image 3 de 3
    • Carefully pry open the back of the back of the laptop using opening picks.
    • Carefully raise and detach the back cover from the laptop.
    • Exercise caution to prevent damaging or cracking the device's back cover.
  4. Dell Inspiron 13 7378 RAM Replacement, RAM: étape 4, image 1 de 3 Dell Inspiron 13 7378 RAM Replacement, RAM: étape 4, image 2 de 3 Dell Inspiron 13 7378 RAM Replacement, RAM: étape 4, image 3 de 3
    • To remove a RAM stick, gently pull apart the metal tabs on either side of the stick.
    • Carefully grasp the stick on its side and pull it out.
    • The plastic sheet covering the RAM compartment depicts the process.
  5. Dell Inspiron 13 7378 RAM Replacement: étape 5, image 1 de 1
    • When inserting the new stick, make sure that the gap on in the stick aligns with the gap in the slot.
Emma Simon
Membre depuis le 02/08/22
165 Réputation
1 tutoriel rédigé
Équipe
Gateway, Team 1-3, Saknee Spring 2022 Membre de l'équipe Gateway, Team 1-3, Saknee Spring 2022
GCC-SAKNEE-S22S1G3
5 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 20
30 derniers jours : 27
Total : 576
