Introduction
In this guide, we will show you how to remove and replace the Hard Drive.
Pièces
Aucune pièce nécessaire.
WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
  • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
  • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
  • Remove the screw that secures the hard-drive assembly to the system board.
Ajouter un commentaire
Slide and disconnect the hard-drive assembly from the connector on the system board as indicated in the illustration.
  • Slide and disconnect the hard-drive assembly from the connector on the system board as indicated in the illustration.
  • Lift the hard-drive assembly off the system board.
  • Remove the four screws that secure the hard-drive bracket to the hard drive.
  • Lift the hard-drive bracket away from the hard drive.
  • Place the NEW hard drive in the hard-drive bracket.
  • Replace the four screws that secure the hard-drive bracket to the hard drive.
  • Place the hard-drive assembly on the system board.
  • Slide and connect the hard-drive assembly to the system board connector.
  • Replace the screw that secures the hard-drive assembly to the system board.
  • Turn over the system board assembly.
Terrence15
Membre depuis le 18/12/2017
69 311 Réputation
444 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
917 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 12
Total : 42
