Aller au contenu principal
Dell Inspiron 13 N3010 Memory Modules Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 13 N3010 Memory Modules Replacement, Popping up the Memory Module: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  2. Dell Inspiron 13 N3010 Memory Modules Replacement, Remove the Memory Module: étape 2, image 1 de 2 Dell Inspiron 13 N3010 Memory Modules Replacement, Remove the Memory Module: étape 2, image 2 de 2
    • Remove the memory module from the memory-module connector.
  3. Dell Inspiron 13 N3010 Memory Modules Replacement, Align the Notch: étape 3, image 1 de 1
    • Align the notch in the NEW memory module with the tab in the memory- module connector.
  4. Dell Inspiron 13 N3010 Memory Modules Replacement, Installing the Memory Module: étape 4, image 1 de 1
    • Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Terrence15
Membre depuis le 12/18/17
79 555 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 111
