Aller au contenu principal
Dell Inspiron 13-5368 Webcam Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 13-5368 Webcam Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 13-5368 Webcam Replacement, Battery: étape 1, image 2 de 2
    • Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
  2. Dell Inspiron 13-5368 Webcam Replacement: étape 2, image 1 de 2 Dell Inspiron 13-5368 Webcam Replacement: étape 2, image 2 de 2
    • Use a spudger to pry up and remove the back cover.
  3. Dell Inspiron 13-5368 Webcam Replacement: étape 3, image 1 de 1
    • Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
  4. Dell Inspiron 13-5368 Webcam Replacement: étape 4, image 1 de 1
    • Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
    • Pull the tab parallel to the motherboard, not straight up.
  5. Dell Inspiron 13-5368 Webcam Replacement: étape 5, image 1 de 2 Dell Inspiron 13-5368 Webcam Replacement: étape 5, image 2 de 2
    • Remove the battery.
  6. Dell Inspiron 13-5368 Webcam Replacement, Screen Display: étape 6, image 1 de 3 Dell Inspiron 13-5368 Webcam Replacement, Screen Display: étape 6, image 2 de 3 Dell Inspiron 13-5368 Webcam Replacement, Screen Display: étape 6, image 3 de 3
    • Unscrew the 2mm screw that holds the WLAN card. Then carefully remove the WLAN card from the motherboard.
  7. Dell Inspiron 13-5368 Webcam Replacement: étape 7, image 1 de 1
    • Detach the black and white antenna cables from the WLAN card.
  8. Dell Inspiron 13-5368 Webcam Replacement: étape 8, image 1 de 1
    • Unplug the two display cables.
  9. Dell Inspiron 13-5368 Webcam Replacement: étape 9, image 1 de 1
    • Unscrew the screws that are securing the laptop's hinges.
  10. Dell Inspiron 13-5368 Webcam Replacement: étape 10, image 1 de 1
    • Detach the display from the base.
  11. Dell Inspiron 13-5368 Webcam Replacement, Webcam: étape 11, image 1 de 1
    • Use your plastic opening tool to pry the LCD back cover from the display panel.
  12. Dell Inspiron 13-5368 Webcam Replacement: étape 12, image 1 de 2 Dell Inspiron 13-5368 Webcam Replacement: étape 12, image 2 de 2
    • Carefully separate the back cover from the LCD screen.
    • Carefully remove the ribbon cable that holds the webcam to the screen, then unplug the webcam from the ribbon cable.
Matt Sugrim
Membre depuis le 09/27/17
1 042 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S14-G6, Boczar Fall 2017 Membre de l'équipe USF Tampa, Team S14-G6, Boczar Fall 2017
USFT-BOCZAR-F17S14G6
4 membres
13 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 17
Total : 1,241
