Aller au contenu principal
Dell Inspiron 13-7347 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 13-7347 Hard Drive Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron 13-7347 Hard Drive Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron 13-7347 Hard Drive Replacement, Battery: étape 1, image 3 de 3
    • Flip the device over, so that the back is facing up.
    • Using a Phillips screwdriver, remove the 10 2.5mm x 8mm screws
    • Use the suction cup to lift off the back case.
  2. Dell Inspiron 13-7347 Hard Drive Replacement: étape 2, image 1 de 3 Dell Inspiron 13-7347 Hard Drive Replacement: étape 2, image 2 de 3 Dell Inspiron 13-7347 Hard Drive Replacement: étape 2, image 3 de 3
    • Remove the two 2mm x 3mm screws that secure the battery to the device.
  3. Dell Inspiron 13-7347 Hard Drive Replacement: étape 3, image 1 de 3 Dell Inspiron 13-7347 Hard Drive Replacement: étape 3, image 2 de 3 Dell Inspiron 13-7347 Hard Drive Replacement: étape 3, image 3 de 3
    • Unplug the cable that connects the USB / SD Reader IO Board to the motherboard.
  4. Dell Inspiron 13-7347 Hard Drive Replacement: étape 4, image 1 de 3 Dell Inspiron 13-7347 Hard Drive Replacement: étape 4, image 2 de 3 Dell Inspiron 13-7347 Hard Drive Replacement: étape 4, image 3 de 3
    • Lift the battery steadily from the device.
    • Tilt the battery upward while removing.
  5. Dell Inspiron 13-7347 Hard Drive Replacement, Hard Drive: étape 5, image 1 de 2 Dell Inspiron 13-7347 Hard Drive Replacement, Hard Drive: étape 5, image 2 de 2
    • Using a Phillips #0 screwdriver, loosen and remove the two 3.0 mm hard drive screws.
    • Lift the hard drive up and out of the device.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 8
Total : 802
