Aller au contenu principal
Dell Inspiron 13-7347 Touchpad Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 13-7347 Touchpad Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron 13-7347 Touchpad Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron 13-7347 Touchpad Replacement, Battery: étape 1, image 3 de 3
    • Flip the device over, so that the back is facing up.
    • Using a Phillips screwdriver, remove the 10 2.5mm x 8mm screws
    • Use the suction cup to lift off the back case.
  2. Dell Inspiron 13-7347 Touchpad Replacement: étape 2, image 1 de 3 Dell Inspiron 13-7347 Touchpad Replacement: étape 2, image 2 de 3 Dell Inspiron 13-7347 Touchpad Replacement: étape 2, image 3 de 3
    • Remove the two 2mm x 3mm screws that secure the battery to the device.
  3. Dell Inspiron 13-7347 Touchpad Replacement: étape 3, image 1 de 3 Dell Inspiron 13-7347 Touchpad Replacement: étape 3, image 2 de 3 Dell Inspiron 13-7347 Touchpad Replacement: étape 3, image 3 de 3
    • Unplug the cable that connects the USB / SD Reader IO Board to the motherboard.
  4. Dell Inspiron 13-7347 Touchpad Replacement: étape 4, image 1 de 3 Dell Inspiron 13-7347 Touchpad Replacement: étape 4, image 2 de 3 Dell Inspiron 13-7347 Touchpad Replacement: étape 4, image 3 de 3
    • Lift the battery steadily from the device.
    • Tilt the battery upward while removing.
  5. Dell Inspiron 13-7347 Touchpad Replacement, Touchpad: étape 5, image 1 de 2 Dell Inspiron 13-7347 Touchpad Replacement, Touchpad: étape 5, image 2 de 2
    • Unplug the sliding connector.
    • The cord is extremely fragile.
  6. Dell Inspiron 13-7347 Touchpad Replacement: étape 6, image 1 de 3 Dell Inspiron 13-7347 Touchpad Replacement: étape 6, image 2 de 3 Dell Inspiron 13-7347 Touchpad Replacement: étape 6, image 3 de 3
    • Flip the cord upward.
  7. Dell Inspiron 13-7347 Touchpad Replacement: étape 7, image 1 de 2 Dell Inspiron 13-7347 Touchpad Replacement: étape 7, image 2 de 2
    • Remove the four 2.5 mm JIS #00 screws.
  8. Dell Inspiron 13-7347 Touchpad Replacement: étape 8, image 1 de 3 Dell Inspiron 13-7347 Touchpad Replacement: étape 8, image 2 de 3 Dell Inspiron 13-7347 Touchpad Replacement: étape 8, image 3 de 3
    • Flip the metal plate upward.
    • Take out the metal plate completely.
  9. Dell Inspiron 13-7347 Touchpad Replacement: étape 9, image 1 de 3 Dell Inspiron 13-7347 Touchpad Replacement: étape 9, image 2 de 3 Dell Inspiron 13-7347 Touchpad Replacement: étape 9, image 3 de 3
    • Remove the touchpad by lifting up the handle.
lee120496
Membre depuis le 02/05/19
643 Réputation
4 tutoriels rédigés
Équipe
UC Davis, Team S20-G8, Lore Winter 2019 Membre de l'équipe UC Davis, Team S20-G8, Lore Winter 2019
UCD-LORE-W19S20G8
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 22
Total : 565
