Aller au contenu principal
Dell Inspiron 13-7352 Cooling Fan Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 13-7352 Cooling Fan Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron 13-7352 Cooling Fan Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron 13-7352 Cooling Fan Replacement, Battery: étape 1, image 3 de 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Cooling Fan Replacement: étape 2, image 1 de 2 Dell Inspiron 13-7352 Cooling Fan Replacement: étape 2, image 2 de 2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Cooling Fan Replacement: étape 3, image 1 de 1
    • Gently remove the battery from the rest of the device.
  4. Dell Inspiron 13-7352 Cooling Fan Replacement, Cooling Fan: étape 4, image 1 de 2 Dell Inspiron 13-7352 Cooling Fan Replacement, Cooling Fan: étape 4, image 2 de 2
    • Remove the cord that runs from system board to the I/O board.
  5. Dell Inspiron 13-7352 Cooling Fan Replacement: étape 5, image 1 de 2 Dell Inspiron 13-7352 Cooling Fan Replacement: étape 5, image 2 de 2
    • Remove the 3mm and 4mm screws holding down fan with the Phillips #0 head.
    • Disconnect the fan wire from the system board.
  6. Dell Inspiron 13-7352 Cooling Fan Replacement: étape 6, image 1 de 1
    • Lift the fan from the rest of the device by picking up a single side and separating it from device.
Chris Monte
Membre depuis le 09/30/15
393 Réputation
2 tutoriels rédigés
Équipe
University of Tampa, Team 1-5, Whiteside Fall 2015 Membre de l'équipe University of Tampa, Team 1-5, Whiteside Fall 2015
UT-WHITESIDE-F15S1G5
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 8
Total : 2,219
