Introduction
This guide will show users through the steps required to replace the main system board.
Ce dont vous avez besoin
Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
Use the plastic opening tool to pry up and loosen the back panel.
Remove the back panel.
Locate your memory module (RAM).
Release the clips from the Memory Module by gently pushing down. This should cause the Memory Module to pop up and separate from the device base.
Remove cord that runs from system board to the I/O board.
Remove connecting wire that runs from fan to system board.
3 autres ont terminé cette réparation.
