Introduction
If you notice your computer programs or computer are slowing, then this guide may be able to help. This guide will show you how to replace the RAM in a few steps.
Pièces
Aucune pièce nécessaire.
  1. WARNING :  Before working inside your computer, read the safety  information that shipped with your computer and follow the steps in  Before working inside your computer . After working inside your  computer, follow the instructions in After working inside your computer.
    • WARNING : Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before working inside your computer . After working inside your computer, follow the instructions in After working inside your computer.
    • Close the display and turn the computer over
    Ajouter un commentaire
  2. Remove the screws that secure the base cover to the computer base.
    • Remove the screws that secure the base cover to the computer base.
  3. Répandez la magie de Noël
    Obtenez 12 $ de réduction sur les commandes de 50 $ ou plus avec le code FIXMAS12
    • Using a plastic scribe (plastic opening tool), pry the base cover off the computer base.
    • Before opening device, ensure that all data is backed up on a hard drive to prevent data loss.
    • Loosen and then unplug the hard drive cable.
    • Remove 2 M2 3mm screws, using the Phillips 1 screwdriver.
    • Remove the battery.
    • Pry open the clips and remove the RAM.
Stephany Marin Restrepo
Membre depuis le 19/03/2018
511 Réputation
5 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 89
