Aller au contenu principal
Dell Inspiron 13-7359 Cooling Fan Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 13-7359 Cooling Fan Replacement, Back Cover: étape 1, image 1 de 1
    • Flip your device over so the back cover is facing you.
    • Using a Phillips #0 Screwdriver, remove the ten 7mm screws holding the back cover in place.
  2. Dell Inspiron 13-7359 Cooling Fan Replacement: étape 2, image 1 de 1
    • Insert a plastic opening and run it along the edge of the back cover. Do this until the entire back cover can be removed.
  3. Dell Inspiron 13-7359 Cooling Fan Replacement, Cooling Fan: étape 3, image 1 de 2 Dell Inspiron 13-7359 Cooling Fan Replacement, Cooling Fan: étape 3, image 2 de 2
    • Unscrew and remove the 2 of the 7mm Phillips head screws holding the cooling fan in place.
  4. Dell Inspiron 13-7359 Cooling Fan Replacement: étape 4, image 1 de 1
    • Hold the cooling fan with one hand.
    • With the other hand, grab hold of the part of the copper heat sink that is attached to the cooling fan.
    • Carefully pull the cooling fan away from the attached part so that it becomes fully disconnected.
2 autres ont terminé cette réparation.
Valentin Medina
Membre depuis le 01/30/18
703 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team S1-G6, Johnson Spring 2018 Membre de l'équipe Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 15
Total : 696
