Aller au contenu principal
Dell Inspiron 13-7359 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 13-7359 Hard Drive Replacement, Back Cover: étape 1, image 1 de 1
    • Flip your device over so the back cover is facing you.
    • Using a Phillips #0 Screwdriver, remove the ten 7mm screws holding the back cover in place.
  2. Dell Inspiron 13-7359 Hard Drive Replacement: étape 2, image 1 de 1
    • Insert a plastic opening and run it along the edge of the back cover. Do this until the entire back cover can be removed.
  3. Dell Inspiron 13-7359 Hard Drive Replacement, Hard Drive: étape 3, image 1 de 1
    • Unscrew and remove the 2 of the 3mm Phillips head screws holding the hard drive in place.
  4. Dell Inspiron 13-7359 Hard Drive Replacement: étape 4, image 1 de 2 Dell Inspiron 13-7359 Hard Drive Replacement: étape 4, image 2 de 2
    • Lift and hold the hard drive in your left hand.
    • Use your right hand to grab hold of the black wire connector attached on the right of the hard drive.
    • Carefully pull the connector away from the hard drive to completely disconnect from the laptop.
6 autres ont terminé cette réparation.
Valentin Medina
Membre depuis le 01/30/18
697 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team S1-G6, Johnson Spring 2018 Membre de l'équipe Baylor, Team S1-G6, Johnson Spring 2018
BU-JOHNSON-S18S1G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 33
Total : 1,977
