Aller au contenu principal
Dell Inspiron 13-7370 Fan Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 13-7370 Fan Replacement, Fan: étape 1, image 1 de 3 Dell Inspiron 13-7370 Fan Replacement, Fan: étape 1, image 2 de 3 Dell Inspiron 13-7370 Fan Replacement, Fan: étape 1, image 3 de 3
    • Make sure the laptop is turned off and not connected to a charging cable.
    • Using a Phillips #0 screwdriver, remove the ten (10) 2.5 mm screws fastening the bottom cover.
  2. Dell Inspiron 13-7370 Fan Replacement: étape 2, image 1 de 2 Dell Inspiron 13-7370 Fan Replacement: étape 2, image 2 de 2
    • Starting around the edges of the laptop, lift and remove the back cover. Apply pressure upwards, until you hear a popping noise.
    • Moving clockwise around the laptop, continue to apply pressure upwards, using your fingers or a plastic pick, until the bottom cover pops out of its locks.
  3. Dell Inspiron 13-7370 Fan Replacement: étape 3, image 1 de 2 Dell Inspiron 13-7370 Fan Replacement: étape 3, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the four 2 mm screws.
    • Carefully disconnect the battery from the motherboard.
  4. Dell Inspiron 13-7370 Fan Replacement: étape 4, image 1 de 2 Dell Inspiron 13-7370 Fan Replacement: étape 4, image 2 de 2
    • Using the Phillips #0 screwdriver, remove the two 2 mm screws holding the fan in place.
  5. Dell Inspiron 13-7370 Fan Replacement: étape 5, image 1 de 3 Dell Inspiron 13-7370 Fan Replacement: étape 5, image 2 de 3 Dell Inspiron 13-7370 Fan Replacement: étape 5, image 3 de 3
    • Lifting the fan, disconnect it from the laptop by grasping the connector (circled in red), and pulling out horizontally.
    • Do NOT pull the connecter upwards, as this may damage the socket you are pulling it out of.
  6. Dell Inspiron 13-7370 Fan Replacement: étape 6, image 1 de 1
    • Remove the fan from the device.
Zayed Azam
Membre depuis le 05/16/21
133 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G6, Melo-Thaiss Summer 2021 Membre de l'équipe York University, Team S1-G6, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S1G6
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 753
