Aller au contenu principal
Dell Inspiron 13-7373 Fan Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 13-7373 Fan Replacement, Back Cover: étape 1, image 1 de 3 Dell Inspiron 13-7373 Fan Replacement, Back Cover: étape 1, image 2 de 3 Dell Inspiron 13-7373 Fan Replacement, Back Cover: étape 1, image 3 de 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Fan Replacement, Fan: étape 2, image 1 de 1
    • Remove the two screws holding the cover for the fan.
  3. Dell Inspiron 13-7373 Fan Replacement: étape 3, image 1 de 1
    • Unplug the connector holding the fan’s wires.
    • Remove the fan from the laptop.
To reassemble your device with the new fan, follow these instructions in reverse order.
2 autres ont terminé cette réparation.
Kameron Jusseaume
Membre depuis le 10/25/19
492 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G4, O'Connell Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G4, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G4
3 membres
5 tutoriels rédigés
2 commentaires
This was most helpful. We have a Dell 7373 model and the fan is quite noisy. We are going to disassemble and clean/replace it. Your tutorial explained it all. Thank you.
martyfukui - Réponse
these 7373 seem to have a fan issue- I do IT for a business that has like 10 of them and at least 2 developed the same issue after a couple years- ordered new fans off of Amazon (tons of them and all look same except some have a flange on the bottom?) and no way to differentiate quality- both redeveloped the problem soon after installing fan- both were clean inside w no obvious issue- guessing the thin case has possibly bent down a tad and puts pressure on it- might take apart and see if I can bend part of case out a bit?) geez dell.
Garry Masters - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 27
Total : 1,296
