Aller au contenu principal
Dell Inspiron 1320 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1320 Hard Drive Replacement, Remove the Four Screws: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the four screws that secure the hard drive assembly to the computer base.
  2. Dell Inspiron 1320 Hard Drive Replacement, Sliding the Hard Drive Assembly: étape 2, image 1 de 1
    • Slide the hard drive assembly to disconnect it from the system board connector.
  3. Dell Inspiron 1320 Hard Drive Replacement, Pull the Black Pull-Tab: étape 3, image 1 de 1
    • Pull the black pull-tab and lift the hard drive assembly out of the computer base.
  4. Dell Inspiron 1320 Hard Drive Replacement, Remove the Screws: étape 4, image 1 de 1
    • Remove the four screws that secure the hard drive to the hard drive cage.
  5. Dell Inspiron 1320 Hard Drive Replacement, Sliding the Hard Drive: étape 5, image 1 de 1
    • Slide the hard drive out of the hard drive cage.
  6. Dell Inspiron 1320 Hard Drive Replacement, Sliding the Hard Drive: étape 6, image 1 de 2 Dell Inspiron 1320 Hard Drive Replacement, Sliding the Hard Drive: étape 6, image 2 de 2
    • Slide the NEW hard drive into the hard drive cage.
  7. Dell Inspiron 1320 Hard Drive Replacement, Replace the Screws: étape 7, image 1 de 1
    • Replace the four screws that secure the hard drive to the hard drive cage.
  8. Dell Inspiron 1320 Hard Drive Replacement, Placing the Hard Drive Assembly: étape 8, image 1 de 1
    • Place the hard drive assembly in the computer base.
  9. Dell Inspiron 1320 Hard Drive Replacement, Connecting the Hard Drive Assembly: étape 9, image 1 de 1
    • Slide and connect the hard drive assembly to the system board connector.
  10. Dell Inspiron 1320 Hard Drive Replacement, Replace the Screws: étape 10, image 1 de 1
    • Replace the four screws that secure the hard drive assembly to the computer base.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 161 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 989 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 8
Total : 378
