Introduction
In this guide, we will show you how to remove and replace the Memory Module.
WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
  • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory-module securing clips.
  • Close the display and turn the computer over.
  • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
Ajouter un commentaire
Remove the memory module from the memory-module connector.
  • Remove the memory module from the memory-module connector.
  • CAUTION: If you need to install memory modules in two connectors, install a memory module in the connector labeled "DIMM A" before you install a memory module in the connector labeled "DIMM B."
  • Align the notch on the memory module with the tab on the memory-module connector.
  • Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
  • NOTE: If the memory module is not in stalled properly, the computer may not boot.
Terrence15
Membre depuis le 18/12/2017
69 311 Réputation
444 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
917 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 7
