Aller au contenu principal
Dell Inspiron 14 3459 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14 3459 Display Assembly Replacement, Sliding the Antenna Cables: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Close the display and turn the computer over.
    • Slide the antenna cables into the slot on the computer base.
  2. Dell Inspiron 14 3459 Display Assembly Replacement, Disconnecting the I/O Board Cable: étape 2, image 1 de 2 Dell Inspiron 14 3459 Display Assembly Replacement, Disconnecting the I/O Board Cable: étape 2, image 2 de 2
    • Turn the computer over and open the display.
    • Open the latch and disconnect the I/O-board cable from the I/O board.
  3. Dell Inspiron 14 3459 Display Assembly Replacement, Removing the Board Cable: étape 3, image 1 de 1
    • Remove the I/O-board cable from the computer base.
  4. Dell Inspiron 14 3459 Display Assembly Replacement, Remove the Antenna Cables: étape 4, image 1 de 1
    • Note the antenna cable routing and remove the antenna cables from the routing guides on the computer base.
  5. Dell Inspiron 14 3459 Display Assembly Replacement, Note the Routing: étape 5, image 1 de 1
    • Note the display cable routing and remove the cable from its routing guides on the computer base.
  6. Dell Inspiron 14 3459 Display Assembly Replacement, Remove the Screws: étape 6, image 1 de 1
    • Remove the screws that secure the display hinges to the computer base.
  7. Dell Inspiron 14 3459 Display Assembly Replacement, Lift the Display Assembly: étape 7, image 1 de 1
    • Lift the display assembly off the computer base.
  8. Dell Inspiron 14 3459 Display Assembly Replacement, Align the Screw Holes: étape 8, image 1 de 1
    • Align the screw holes on the display hinges with the screw holes on the computer base.
  9. Dell Inspiron 14 3459 Display Assembly Replacement, Replace the Screws: étape 9, image 1 de 1
    • Replace the screws that secure the display hinges to the computer base.
  10. Dell Inspiron 14 3459 Display Assembly Replacement, Route the Display Cable: étape 10, image 1 de 1
    • Route the display cable through the routing guides on the computer base.
  11. Dell Inspiron 14 3459 Display Assembly Replacement, Route the Antenna Cables: étape 11, image 1 de 1
    • Route the antenna cables through the routing guides on the computer base and slide the antenna cables through the slot on the computer base.
  12. Dell Inspiron 14 3459 Display Assembly Replacement, Sliding the I/O Board Cable: étape 12, image 1 de 1
    • Slide the I/O-board cable into the I/O board and close the latch to secure the cable.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 131 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 986 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 11
Total : 600
