Aller au contenu principal
Dell Inspiron 14 3462 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14 3462 Display Assembly Replacement, Peel the Tape: étape 1, image 1 de 1
  2. Dell Inspiron 14 3462 Display Assembly Replacement, Disconnecting the Display Cable: étape 2, image 1 de 1
    • Open the latch that secures the display cable into position.
    • Disconnect the display cable from the system board.
  3. Dell Inspiron 14 3462 Display Assembly Replacement, Remove the Antenna Cable: étape 3, image 1 de 1
    • Note the antenna-cable routing, and remove the antenna cable from the routing guides on the palm-rest assembly.
  4. Dell Inspiron 14 3462 Display Assembly Replacement, Turn the Computer Over: étape 4, image 1 de 1
    • Turn the computer over and open the display at an angle of 90 degrees.
    • Turn the computer over and place it on the edge of the table in a position that allows access to the screws on the display hinges.
  5. Dell Inspiron 14 3462 Display Assembly Replacement, Remove the Screws: étape 5, image 1 de 1
    • Remove the three screws (M2.5x8) that secure the display-hinge brackets to the palm-rest assembly.
  6. Dell Inspiron 14 3462 Display Assembly Replacement, Lifting the Display Assembly: étape 6, image 1 de 1
    • Carefully lift the display assembly from the palm-rest assembly.
  7. Dell Inspiron 14 3462 Display Assembly Replacement, Placing the Display Assembly: étape 7, image 1 de 1
    • Carefully place the display assembly on a clean and flat surface.
  8. Dell Inspiron 14 3462 Display Assembly Replacement, Placing the Display Assembly: étape 8, image 1 de 1
    • Place the NEW display assembly at the edge of the table.
  9. Dell Inspiron 14 3462 Display Assembly Replacement, Align the Screw Holes: étape 9, image 1 de 1
    • Align the screw holes on the palm-rest assembly with the screw holes on the display hinges.
  10. Dell Inspiron 14 3462 Display Assembly Replacement, Replace the Screws: étape 10, image 1 de 1
    • Replace the three screws (M2.5x8) that secure the display hinges to the palm-rest assembly.
  11. Dell Inspiron 14 3462 Display Assembly Replacement, Route the Cables: étape 11, image 1 de 1
    • Route the antenna cables through the routing guides on the palm-rest assembly.
  12. Dell Inspiron 14 3462 Display Assembly Replacement, Connecting the Display Cable: étape 12, image 1 de 1
    • Connect the display cable from the system board.
  13. Dell Inspiron 14 3462 Display Assembly Replacement, Close the Latch: étape 13, image 1 de 1
    • Close the latch that secures the display cable to the system board.
  14. Dell Inspiron 14 3462 Display Assembly Replacement, Adhering the Tape: étape 14, image 1 de 1
    • Adhere the tape that secures the display cable to the system board.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 212
