Aller au contenu principal
Dell Inspiron 14 7447 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14 7447 Hard Drive Replacement, Disconnecting the Hard-Drive Cable: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: To avoid data loss, do not remove the hard drive while the computer is in Sleep or On state.
    • Using the pull-tab, disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 14 7447 Hard Drive Replacement, Remove the Screws: étape 2, image 1 de 1
    • Remove the screws that secure the hard-drive assembly to the computer base.
  3. Dell Inspiron 14 7447 Hard Drive Replacement, Lifting the Hard-Drive Assembly: étape 3, image 1 de 1
    • Gently lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 14 7447 Hard Drive Replacement, Disconnecting the Interposer: étape 4, image 1 de 1
    • Disconnect the interposer from the hard drive.
  5. Dell Inspiron 14 7447 Hard Drive Replacement, Remove the Screws: étape 5, image 1 de 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 14 7447 Hard Drive Replacement, Lifting the Hard Drive: étape 6, image 1 de 2 Dell Inspiron 14 7447 Hard Drive Replacement, Lifting the Hard Drive: étape 6, image 2 de 2
    • Lift the hard drive out of the hard-drive bracket.
  7. Dell Inspiron 14 7447 Hard Drive Replacement, Connecting the Interposer: étape 7, image 1 de 1
    • Connect the interposer to the NEW hard drive.
  8. Dell Inspiron 14 7447 Hard Drive Replacement, Align the Screw Holes: étape 8, image 1 de 1
    • Align the screw holes on the hard drive-bracket with the screw holes on the hard drive.
  9. Dell Inspiron 14 7447 Hard Drive Replacement, Replace the Screws: étape 9, image 1 de 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 14 7447 Hard Drive Replacement, Placing the Hard-Drive: étape 10, image 1 de 1
    • Place the hard-drive assembly into the hard-drive bay.
  11. Dell Inspiron 14 7447 Hard Drive Replacement, Align the Screw Holes: étape 11, image 1 de 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  12. Dell Inspiron 14 7447 Hard Drive Replacement, Replace the Screws: étape 12, image 1 de 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
  13. Dell Inspiron 14 7447 Hard Drive Replacement, Connecting the Hard-Drive Cable: étape 13, image 1 de 1
    • Connect the hard-drive cable to the system board.
Terrence15
Membre depuis le 12/18/17
79 522 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 5
Total : 1,204
