Aller au contenu principal
Dell Inspiron 14 Gaming 7466 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14 Gaming 7466 Hard Drive Replacement, Disconnecting the Hard Drive Cable: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • CAUTION: The latch on the hard-drive locking connector is fragile. Pulling the latch forcefully may damage the hard-drive locking connector. Exercise care when handling the latch on the hard-drive locking connector.
    • Using a plastic scribe, lift the latch and use the pull tab to disconnect the hard-drive cable from the system board.
  2. Dell Inspiron 14 Gaming 7466 Hard Drive Replacement, Remove the Screws: étape 2, image 1 de 1
    • Remove the four screws (M2.5x3 Ladder type) that secure the hard-drive assembly to the computer base.
  3. Dell Inspiron 14 Gaming 7466 Hard Drive Replacement, Lifting the Hard Drive Assembly: étape 3, image 1 de 1
    • Lift the hard-drive assembly, along with its cable, off the computer base.
  4. Dell Inspiron 14 Gaming 7466 Hard Drive Replacement, Disconnecting the Interposer: étape 4, image 1 de 1
    • Disconnect the interposer from the hard-drive assembly.
  5. Dell Inspiron 14 Gaming 7466 Hard Drive Replacement, Remove the Screws: étape 5, image 1 de 1
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 14 Gaming 7466 Hard Drive Replacement, Remove the Hard-Drive Bracket: étape 6, image 1 de 1
    • Remove the hard-drive bracket off the hard drive.
  7. Dell Inspiron 14 Gaming 7466 Hard Drive Replacement, Align the Screw Holes: étape 7, image 1 de 1
    • Align the screw holes on the hard drive-bracket with the screw holes on the NEW hard drive.
  8. Dell Inspiron 14 Gaming 7466 Hard Drive Replacement, Replace the Screws: étape 8, image 1 de 1
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  9. Dell Inspiron 14 Gaming 7466 Hard Drive Replacement, Connecting the Interposer: étape 9, image 1 de 1
    • Connect the interposer to the hard drive.
  10. Dell Inspiron 14 Gaming 7466 Hard Drive Replacement, Align the Screw Holes: étape 10, image 1 de 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  11. Dell Inspiron 14 Gaming 7466 Hard Drive Replacement, Replace the Screws: étape 11, image 1 de 1
    • Replace the four screws (M2.5x3 Ladder type) that secure the hard-drive assembly to the computer base.
  12. Dell Inspiron 14 Gaming 7466 Hard Drive Replacement, Connect the Hard Drive Cable: étape 12, image 1 de 1
    • Connect the hard-drive cable to the system board.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 309 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 984 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 92
