Introduction
In this guide, we will show you how to remove and replace the Display Assembly.
Pièces
Aucune pièce nécessaire.
WARNING: Before working inside your computer, read the safety information  that shipped with your computer.
  • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
  • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
  • Disconnect the display cable from the connector on the system board.
Ajouter un commentaire
Disconnect the Mini-Card antenna cables from the connectors on the  Mini-Card.
  • Disconnect the Mini-Card antenna cables from the connectors on the Mini-Card.
  • Make a note of the display cable and Mini-Card antenna cables routing and remove the cables from the routing guides.
  • Remove the two screws that secure the display assembly to the computer base.
  • Lift and remove the display assembly out of the computer base.
  • Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base.
  • Route the display cable and Mini-Card antenna cables through the routing guides.
  • Connect the display cable to the connector on the system board.
Ligne d'arrivée
Terrence15
Membre depuis le 18/12/2017
69 301 Réputation
444 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
917 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 7
