Aller au contenu principal
Dell Inspiron 14 M4040 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14 M4040 Hard Drive Replacement, Disconnecting the Hard-Drive Assembly: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: Hard drives are extremely fragile. Exercise care when handling the hard drive.
    • Slide the hard-drive assembly to the left to disconnect it from the connector on the system board.
  2. Dell Inspiron 14 M4040 Hard Drive Replacement, Lifting the Hard-Drive Assembly: étape 2, image 1 de 1
    • Lift the hard-drive assembly out of the computer base.
  3. Dell Inspiron 14 M4040 Hard Drive Replacement, Remove the Screws: étape 3, image 1 de 1
    • Remove the two screws that secure the hard-drive bracket to the hard drive.
  4. Dell Inspiron 14 M4040 Hard Drive Replacement, Placing the Hard Drive: étape 4, image 1 de 2 Dell Inspiron 14 M4040 Hard Drive Replacement, Placing the Hard Drive: étape 4, image 2 de 2
    • Place the hard-drive bracket on the NEW hard drive.
  5. Dell Inspiron 14 M4040 Hard Drive Replacement, Replace the Two Screws: étape 5, image 1 de 1
    • Replace the two screws that secure the hard-drive bracket to the hard drive.
  6. Dell Inspiron 14 M4040 Hard Drive Replacement, Placing the Hard Drive Assembly: étape 6, image 1 de 1
    • Place the hard-drive assembly on the computer base.
  7. Dell Inspiron 14 M4040 Hard Drive Replacement, Pushing the Hard-Drive Assembly: étape 7, image 1 de 1
    • Push the hard-drive assembly towards the right to connect it to the connector on the system board.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 555 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 12
Total : 212
