Aller au contenu principal
Dell Inspiron 14 N4030 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14 N4030 Hard Drive Replacement, Remove the Screws: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 14 N4030 Hard Drive Replacement, Sliding the Assembly: étape 2, image 1 de 1
    • Slide the hard-drive assembly out of the hard-drive compartment.
  3. Dell Inspiron 14 N4030 Hard Drive Replacement, Remove the Screws: étape 3, image 1 de 1
    • Remove the two screws that secure the hard-drive bezel to the hard drive.
  4. Dell Inspiron 14 N4030 Hard Drive Replacement, Removing the Hard Drive: étape 4, image 1 de 1
    • Pull the hard-drive bezel away from the hard drive.
  5. Dell Inspiron 14 N4030 Hard Drive Replacement, Align the Screw Holes: étape 5, image 1 de 1
    • Align the screw holes on the NEW hard-drive bezel with the screw holes on the hard drive and replace the two screws.
  6. Dell Inspiron 14 N4030 Hard Drive Replacement, Sliding the Hard-Drive Assembly: étape 6, image 1 de 1
    • Slide the hard-drive assembly into the hard-drive compartment until it is fully seated.
  7. Dell Inspiron 14 N4030 Hard Drive Replacement, Replace the Screws: étape 7, image 1 de 1
    • Replace the two screws that secure the hard-drive assembly to the computer base.
Ligne d'arrivée
2 autres ont terminé cette réparation.
Terrence15
Membre depuis le 12/18/17
79 555 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 15
Total : 1,142
