Aller au contenu principal
Dell Inspiron 14 N4050 Display Assembly Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14 N4050 Display Assembly Replacement, Disconnecting the Display Cable: étape 1, image 1 de 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Disconnect the display cable from the connector on the system board.
  2. Dell Inspiron 14 N4050 Display Assembly Replacement, Disconnecting the Mini-Card Antenna Cables: étape 2, image 1 de 1
    • Disconnect the Mini-Card antenna cables from the connectors on the Mini-Card.
  3. Dell Inspiron 14 N4050 Display Assembly Replacement, Removing the Cables: étape 3, image 1 de 1
    • Make a note of the display cable and Mini-Card antenna cables routing and remove the cables from the routing guides.
  4. Dell Inspiron 14 N4050 Display Assembly Replacement, Remove the Screws: étape 4, image 1 de 1
    • Remove the two screws that secure the display assembly to the computer base.
  5. Dell Inspiron 14 N4050 Display Assembly Replacement, Removing the Display Assembly: étape 5, image 1 de 1
    • Lift and remove the display assembly out of the computer base.
  6. Dell Inspiron 14 N4050 Display Assembly Replacement, Placing the Display Assembly: étape 6, image 1 de 1
    • Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base.
  7. Dell Inspiron 14 N4050 Display Assembly Replacement, Routing the Display Cable: étape 7, image 1 de 1
    • Route the display cable and Mini-Card antenna cables through the routing guides.
  8. Dell Inspiron 14 N4050 Display Assembly Replacement, Connecting the Display Cable: étape 8, image 1 de 1
    • Connect the display cable to the connector on the system board.
  9. Dell Inspiron 14 N4050 Display Assembly Replacement, Conencting the Antenna Cables: étape 9, image 1 de 2 Dell Inspiron 14 N4050 Display Assembly Replacement, Conencting the Antenna Cables: étape 9, image 2 de 2
    • Connect the Mini-Card antenna cables to the Mini-Card.
Ligne d'arrivée
Terrence15
Membre depuis le 12/18/17
79 121 Réputation
441 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 8
Total : 677
