Introduction
This step-by-step guide will show how to replace the RAM (Random Access Memory) stick in your Inspiron 14-3452 with a new one. All you need is a spudger and a screwdriver.
Pièces
Aucune pièce nécessaire.
Remove the battery by sliding the battery release latch to the left.
  • Remove the battery by sliding the battery release latch to the left.
  • Pull the entire battery away from the backing.
Ajouter un commentaire
Ensure that the laptop is completely turned off and the battery is removed.
  • Ensure that the laptop is completely turned off and the battery is removed.
  • Remove the two Phillips Head 5 mm #0 screws holding the backing in place.
  • Pull the backing away from the laptop.
  • Locate the blue RAM chip sitting in the RAM bay.
  • Use your fingertips to pry apart the white RAM securing-clips on each side of the memory-module slot until the RAM chip pops up.
  • Pull the RAM chip away from the memory-module slot.
  • The RAM chip is now fully detached and ready to be replaced.
Alec Siegel
Membre depuis le 30/01/2018
505 Réputation
4 tutoriels rédigés
Équipe
Baylor, Team S2-G2, Johnson Spring 2018 Membre de l'équipe Baylor, Team S2-G2, Johnson Spring 2018
BU-JOHNSON-S18S2G2
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 86
