Aller au contenu principal
Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement, Battery: étape 1, image 2 de 2
    • Remove the battery by sliding the battery release latch to the left.
    • Pull the entire battery away from the backing.
  2. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement, Random Access Memory (RAM): étape 2, image 1 de 1
    • Ensure that the laptop is completely turned off and the battery is removed.
    • Remove the two Phillips Head 5 mm #0 screws holding the backing in place.
  3. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement: étape 3, image 1 de 1
    • Pull the backing away from the laptop.
  4. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement: étape 4, image 1 de 1
    • Locate the blue RAM chip sitting in the RAM bay.
    • Use your fingertips to pry apart the white RAM securing-clips on each side of the memory-module slot until the RAM chip pops up.
  5. Dell Inspiron 14-3452 Random Access Memory (RAM) Replacement: étape 5, image 1 de 1
    • Pull the RAM chip away from the memory-module slot.
    • The RAM chip is now fully detached and ready to be replaced.
2 autres ont terminé cette réparation.
Alec Siegel
Membre depuis le 01/30/18
598 Réputation
4 tutoriels rédigés
Équipe
Baylor, Team S2-G2, Johnson Spring 2018 Membre de l'équipe Baylor, Team S2-G2, Johnson Spring 2018
BU-JOHNSON-S18S2G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 19
30 derniers jours : 30
Total : 891
