Aller au contenu principal
Dell Inspiron 14-3452 Screen Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14-3452 Screen Replacement, Battery: étape 1, image 1 de 2 Dell Inspiron 14-3452 Screen Replacement, Battery: étape 1, image 2 de 2
    • Remove the battery by sliding the battery release latch to the left.
    • Pull the entire battery away from the backing.
  2. Dell Inspiron 14-3452 Screen Replacement, Random Access Memory (RAM): étape 2, image 1 de 1
    • Ensure that the laptop is completely turned off and the battery is removed.
    • Remove the two Phillips Head 5 mm #0 screws holding the backing in place.
  3. Dell Inspiron 14-3452 Screen Replacement: étape 3, image 1 de 1
    • Pull the backing away from the laptop.
  4. Dell Inspiron 14-3452 Screen Replacement: étape 4, image 1 de 1
    • Locate the blue RAM chip sitting in the RAM bay.
    • Use your fingertips to pry apart the white RAM securing-clips on each side of the memory-module slot until the RAM chip pops up.
  5. Dell Inspiron 14-3452 Screen Replacement: étape 5, image 1 de 1
    • Pull the RAM chip away from the memory-module slot.
    • The RAM chip is now fully detached and ready to be replaced.
  6. Dell Inspiron 14-3452 Screen Replacement, Screen: étape 6, image 1 de 1
    • Remove the ten Phillips Head 5 mm #0 screws from the computer backing.
    • Remove the one Phillips Head 3 mm #0 screw from the computer backing.
  7. Dell Inspiron 14-3452 Screen Replacement: étape 7, image 1 de 2 Dell Inspiron 14-3452 Screen Replacement: étape 7, image 2 de 2
    • Remove the white and black antenna cables from the wireless card.
  8. Dell Inspiron 14-3452 Screen Replacement: étape 8, image 1 de 1
    • Remove the Phillips Head 3 mm #0 screw that is holding the wireless card in place.
  9. Dell Inspiron 14-3452 Screen Replacement: étape 9, image 1 de 1
    • Slide the wireless card out of the wireless card bay.
  10. Dell Inspiron 14-3452 Screen Replacement: étape 10, image 1 de 2 Dell Inspiron 14-3452 Screen Replacement: étape 10, image 2 de 2
    • Using your fingertips remove the speaker cable from the motherboard by pulling the white connector away from the socket.
  11. Dell Inspiron 14-3452 Screen Replacement: étape 11, image 1 de 1
    • Pry apart the keyboard assembly slowly as the keyboard cable will still be attached to the motherboard.
    • Use the blue Uspudger to pry apart the keyboard assembly from the bottom shell.
  12. Dell Inspiron 14-3452 Screen Replacement: étape 12, image 1 de 1
    • Disconnect the keyboard cable from the motherboard by lifting the black latch and pulling the cable out of its socket.
  13. Dell Inspiron 14-3452 Screen Replacement: étape 13, image 1 de 2 Dell Inspiron 14-3452 Screen Replacement: étape 13, image 2 de 2
    • Disconnect the display cable from the motherboard by pulling the tape back and lifting the connector latch.
    • Pull the display cable away from the motherboard.
  14. Dell Inspiron 14-3452 Screen Replacement: étape 14, image 1 de 1
    • Remove the power adapter cable from the motherboard by sliding the cable out of its socket.
  15. Dell Inspiron 14-3452 Screen Replacement: étape 15, image 1 de 1
    • Turn laptop over to access the screen hinge screws.
    • Remove the two Phillips Head 5 mm #0 screws from the two hinges.
  16. Dell Inspiron 14-3452 Screen Replacement: étape 16, image 1 de 2 Dell Inspiron 14-3452 Screen Replacement: étape 16, image 2 de 2
    • Using your fingertips, gently pry up the inner edges of the display bezel.
    • Lift the display bezel off the display assembly.
  17. Dell Inspiron 14-3452 Screen Replacement: étape 17, image 1 de 3 Dell Inspiron 14-3452 Screen Replacement: étape 17, image 2 de 3 Dell Inspiron 14-3452 Screen Replacement: étape 17, image 3 de 3
    • After removing the bezel, locate the tab indicated in the pictures.
    • Lift the tab as shown in the pictures.
    • Lift the gold latch securing the display cable to the socket.
    • Pull display cable away from the socket.
Alec Siegel
Membre depuis le 01/30/18
598 Réputation
4 tutoriels rédigés
Équipe
Baylor, Team S2-G2, Johnson Spring 2018 Membre de l'équipe Baylor, Team S2-G2, Johnson Spring 2018
BU-JOHNSON-S18S2G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 19
30 derniers jours : 27
Total : 975
