Aller au contenu principal
Dell Inspiron 14-5415 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14-5415 Hard Drive Replacement, Back Cover: étape 1, image 1 de 1
    • Close the lid and turn the laptop over to access the back cover.
  2. Dell Inspiron 14-5415 Hard Drive Replacement: étape 2, image 1 de 1
    • Remove the five 4 mm screws from the back of the laptop using a Phillips #0 screwdriver.
    • Loosen the two remaining captive screws using a Phillips #0 screwdriver.
    • Captive screws tend to have a slightly larger head than normal screws, so it is important to use the correct size screwdriver to avoid damaging the screw or the device.
  3. Dell Inspiron 14-5415 Hard Drive Replacement, Hard Drive: étape 3, image 1 de 2 Dell Inspiron 14-5415 Hard Drive Replacement, Hard Drive: étape 3, image 2 de 2
    • Remove the screw from the hard drive using a Phillips #00 screwdriver.
  4. Dell Inspiron 14-5415 Hard Drive Replacement: étape 4, image 1 de 1
    • Carefully pull the hard drive out of its position.
    • Be sure to handle the hard drive with care. It should not need to be pulled hard to remove.
Ilana Ek-Adler
Membre depuis le 02/09/23
85 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 10
30 derniers jours : 18
Total : 345
