Aller au contenu principal
Dell Inspiron 14-5415 RAM Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14-5415 RAM Replacement, Back Cover: étape 1, image 1 de 1
    • Close the lid and turn the laptop over to access the back cover.
  2. Dell Inspiron 14-5415 RAM Replacement: étape 2, image 1 de 1
    • Remove the five 4 mm screws from the back of the laptop using a Phillips #0 screwdriver.
    • Loosen the two remaining captive screws using a Phillips #0 screwdriver.
    • Captive screws tend to have a slightly larger head than normal screws, so it is important to use the correct size screwdriver to avoid damaging the screw or the device.
  3. Dell Inspiron 14-5415 RAM Replacement, RAM: étape 3, image 1 de 1
    • To access the Dell Inspiron RAM, turn the device upside down.
    • The fan should be positioned In the top right hand corner of the device.
    • The Dell logo on the battery pack should be in an upright position when locating parts.
  4. Dell Inspiron 14-5415 RAM Replacement: étape 4, image 1 de 3 Dell Inspiron 14-5415 RAM Replacement: étape 4, image 2 de 3 Dell Inspiron 14-5415 RAM Replacement: étape 4, image 3 de 3
    • Raise the thin plastic tab that is covering the RAM.
    • Gently dislodge the metal hooks that are on both sides of the RAM by slightly pulling them apart.
    • The metal hooks are very thin, be sure not to bend them while dislodging them.
  5. Dell Inspiron 14-5415 RAM Replacement: étape 5, image 1 de 2 Dell Inspiron 14-5415 RAM Replacement: étape 5, image 2 de 2
    • Gently pull on both sides the RAM to remove it.
    • Make sure to be gentle, as small scratches can permanently damage the RAM.
Nwachukwu Izuogu
Membre depuis le 02/09/23
234 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 13
30 derniers jours : 28
Total : 460
