Aller au contenu principal
Dell Inspiron 14-5447 Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14-5447 Battery Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop upside down to access the battery.
  2. Dell Inspiron 14-5447 Battery Replacement: étape 2, image 1 de 2 Dell Inspiron 14-5447 Battery Replacement: étape 2, image 2 de 2
    • Remove the two black 5.70mm Phillips#0 screws on the case's back.
    • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
  3. Dell Inspiron 14-5447 Battery Replacement: étape 3, image 1 de 2 Dell Inspiron 14-5447 Battery Replacement: étape 3, image 2 de 2
    • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
    • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
  4. Dell Inspiron 14-5447 Battery Replacement: étape 4, image 1 de 2 Dell Inspiron 14-5447 Battery Replacement: étape 4, image 2 de 2
    • Use the black, plastic flap on the left side to pull the battery out.
    • Slowly lift the flap up and the battery should slide out.
4 autres ont terminé cette réparation.
Isabella Chavez
Membre depuis le 04/11/17
476 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 10
Total : 3,141
