Aller au contenu principal
Dell Inspiron 14-5447 Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14-5447 Wi-Fi Card Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop upside down to access the battery.
  2. Dell Inspiron 14-5447 Wi-Fi Card Replacement: étape 2, image 1 de 2 Dell Inspiron 14-5447 Wi-Fi Card Replacement: étape 2, image 2 de 2
    • Remove the two black 5.70mm Phillips#0 screws on the case's back.
    • Insert a plastic opening tool into the small slit, centered between the removed screws, and pry open the back cover
  3. Dell Inspiron 14-5447 Wi-Fi Card Replacement: étape 3, image 1 de 2 Dell Inspiron 14-5447 Wi-Fi Card Replacement: étape 3, image 2 de 2
    • Remove the two 5.70mm Phillips #0 screws that secure the battery in place on its left side .
    • Treat the battery with care - puncturing or bending may cause damage to the battery and may result in fire or injury.
  4. Dell Inspiron 14-5447 Wi-Fi Card Replacement: étape 4, image 1 de 2 Dell Inspiron 14-5447 Wi-Fi Card Replacement: étape 4, image 2 de 2
    • Use the black, plastic flap on the left side to pull the battery out.
    • Slowly lift the flap up and the battery should slide out.
  5. Dell Inspiron 14-5447 Wi-Fi Card Replacement, Wi-Fi Card: étape 5, image 1 de 2 Dell Inspiron 14-5447 Wi-Fi Card Replacement, Wi-Fi Card: étape 5, image 2 de 2
    • Locate the Wifi card on the top left of the laptop.
    • Use the tweezers to release the black and white cables.
  6. Dell Inspiron 14-5447 Wi-Fi Card Replacement: étape 6, image 1 de 1
    • Remove one silver 2.9mm Phillips #1 screw which secures the WiFi card.
  7. Dell Inspiron 14-5447 Wi-Fi Card Replacement: étape 7, image 1 de 1
    • The Wi-Fi card should slide out of the black socket.
    • Use tweezers to push the white part of the Wi-Fi card up towards the top of the device to remove.
    • Remove the card with the tweezers.
Isabella Chavez
Membre depuis le 04/11/17
476 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 1,226
