Aller au contenu principal
Dell Inspiron 14-7437 Coin Cell Battery Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Base Cover: étape 1, image 1 de 2 Dell Inspiron 14-7437 Coin Cell Battery Replacement, Base Cover: étape 1, image 2 de 2
    • Power off your Dell Inspiron 14-7437 before disassembling.
    • Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
    • The two 4.5 mm screws in the center under the rubber mount cannot be removed, but can be loosened.
  2. Dell Inspiron 14-7437 Coin Cell Battery Replacement: étape 2, image 1 de 2 Dell Inspiron 14-7437 Coin Cell Battery Replacement: étape 2, image 2 de 2
    • Pry open the back cover using a spudger and slide it along the under the cover.
  3. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Battery: étape 3, image 1 de 2 Dell Inspiron 14-7437 Coin Cell Battery Replacement, Battery: étape 3, image 2 de 2
    • Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
  4. Dell Inspiron 14-7437 Coin Cell Battery Replacement: étape 4, image 1 de 1
    • Disconnect the ribbon cables from the motherboard.
  5. Dell Inspiron 14-7437 Coin Cell Battery Replacement: étape 5, image 1 de 1
    • Lift up and remove the Lithium-Polymer Battery.
  6. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Speaker: étape 6, image 1 de 1
    • Disconnect wires from Motherboard by gently pulling up.
  7. Dell Inspiron 14-7437 Coin Cell Battery Replacement: étape 7, image 1 de 3 Dell Inspiron 14-7437 Coin Cell Battery Replacement: étape 7, image 2 de 3 Dell Inspiron 14-7437 Coin Cell Battery Replacement: étape 7, image 3 de 3
    • Remove the speakers from the case.
  8. Dell Inspiron 14-7437 Coin Cell Battery Replacement, Coin Cell Battery: étape 8, image 1 de 1
    • Lift the coin cell battery wire, and carefully remove from motherboard.
    • There are little hooks that the wire is hooked under.
  9. Dell Inspiron 14-7437 Coin Cell Battery Replacement: étape 9, image 1 de 2 Dell Inspiron 14-7437 Coin Cell Battery Replacement: étape 9, image 2 de 2
    • Remove the Coin-Cell Battery from the case.
    • There is a small amount of adhesive on the bottom of the coin cell battery.
Katelyn Remy
Membre depuis le 03/10/16
449 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team 7-8, Catania Spring 2016 Membre de l'équipe UMass Dartmouth, Team 7-8, Catania Spring 2016
UMASSD-CATANIA-S16S7G8
3 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 20
Total : 1,405
