Aller au contenu principal
Dell Inspiron 1420 Display Replacement
Ce dont vous avez besoin
  1. Dell Inspiron 1420 Display Replacement, Battery: étape 1, image 1 de 3 Dell Inspiron 1420 Display Replacement, Battery: étape 1, image 2 de 3 Dell Inspiron 1420 Display Replacement, Battery: étape 1, image 3 de 3
    • Slide the two tabs to release the battery.
    • Pull the battery out.
  2. Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: étape 2, image 1 de 3 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: étape 2, image 2 de 3 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: étape 2, image 3 de 3
    • Use a spudger to pry the 6 rubber bumpers from the display.
    • Using a Phillips #00 screwdriver, remove the six 4mm screws that are beneath the six rubber bumpers.
  3. Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: étape 3, image 1 de 3 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: étape 3, image 2 de 3 Dell Inspiron 1420 Display Replacement, Removing the Outer Frame: étape 3, image 3 de 3
    • Gently pry the frame using a spudger.
    • Using a Phillips #00 screwdriver, remove the two 5mm screws at the bottom of the screen.
  4. Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: étape 4, image 1 de 3 Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: étape 4, image 2 de 3 Dell Inspiron 1420 Display Replacement, Separating the Display from the Frame: étape 4, image 3 de 3
    • Use a spudger to loosen the frame from the top.
    • Lift up the black connector to detach the gold ribbon.
  5. Dell Inspiron 1420 Display Replacement, Removing the Power Connector Cable: étape 5, image 1 de 2 Dell Inspiron 1420 Display Replacement, Removing the Power Connector Cable: étape 5, image 2 de 2
    • Pull directly up on the light blue tab.
  6. Dell Inspiron 1420 Display Replacement, VGA cable: étape 6, image 1 de 3 Dell Inspiron 1420 Display Replacement, VGA cable: étape 6, image 2 de 3 Dell Inspiron 1420 Display Replacement, VGA cable: étape 6, image 3 de 3
    • Squeeze the two metal clips located on the VGA cable.
    • Pull while squeezing the clips in order to remove the cable.
  7. Dell Inspiron 1420 Display Replacement, Isolating the Display: étape 7, image 1 de 3 Dell Inspiron 1420 Display Replacement, Isolating the Display: étape 7, image 2 de 3 Dell Inspiron 1420 Display Replacement, Isolating the Display: étape 7, image 3 de 3
    • Using a Phillips #00 screwdriver, remove the three 3mm screws located on both the left and right side of the laptop.
    • Remove the metal brackets, one on each side, by gently pulling.
3 autres ont terminé cette réparation.
Kris Karanxha
Membre depuis le 09/23/14
298 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 2-4, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 2-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G4
4 membres
5 tutoriels rédigés
0Commentaires sur le guide
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 42
Total : 2,585
